Kawasaki released the Teryx 4 H2 today! 250HP
Now to the stock cage. I’m not a fan of all the bolt on cage parts or lack of triangulation. But I was able to feel the thickness of the tubes, and if it’s not .095 then it’s close. The stock cage & chassis have 10 mounting points. I’m not a fan of how the A pillar is not inline with the A pillar mounting points. They laid it back to rake back the A pillar. IMO I would make the tube clamp and tube aline and they would stand the A pillar/windshield more upright. This would also move the upper visor roof bar more forward. Doing this you could probably add an A+ tube on the cage and tie into the chassis making it way stronger in that area. Also in some bends Kawi has added formed gussets, and in some places they welded a sleeve over the tube to add strength in that bend. I still think an aftermarket cage will look much better and offer more strength. But for stock, it’s better than many others. IMO the plastic roof is hideous. But that’s just me. I’d rather have a smooth aluminum roof panel.
View attachment 156525View attachment 156526View attachment 156527View attachment 156528
Notice the wonky angle change from the cage bung clamp and the A pillar tube. IMO they should stand up the A pillar and made both inline. Plus you might be able to add a A plus bar on a aftermarket cage.
I'll agree that "more bars and triangulation" helps strengthen a chassis, aftermarket bolt on intrusion bar for the A pillar would be a nice add.
I disagree that the A pillar angle is dangerous - only direct impact would benefit from it being inline vs the slight angle it has now. No typical crash will put force in that direction for it to be the benefit your talking about. It's an esthetic issue for you perhaps? Like Rolled roof lines vs straight...its a visual preference.
  • Enthusiast speculation: Off-road forums often feature discussions based on visual assessment rather than engineering data. The A-pillar angle is visually prominent, but its performance in a rollover is determined by the specific materials, thickness, and mounting points of the entire ROPS, not just its outward appearance.
That’s cool. It’s literally a Garmin Tread and not some cheaper production unit just made for the Kawi with the Garmin name on it. Unfortunately that happens allot where they license a brand name but that brand does not actually make the product or it’s a cheaper version vs the real part.
Plus if you have an issue or want to clean the car in that area you can pull the unit out. I like it!
Nothing dangerous about that cage (or really any SxS cage on a current offering). Is there room for improvement? Absolutely.
I've seen a shitload of wrecks out there. I've only seen one frightening failure, and that was a dude who absolutely yarded it almost directly onto the roof. He still walked away...
Wow Parker and I get nothin for my write up! Not even a Weekly Reader or Pennysaver contract? 😢
Wait, @NIKAL—I thought that was you in the video! Now Dave’s gonna have to write up two contracts. 😂
All jokes aside, your write-up was solid and I really appreciate you taking the time. Posts like that are what make this forum great—straightforward, unbiased reviews from guys who actually have a clue and have been in the off-road scene for years, not just some BS sponsored magazine fluff.
Another video posted by UTV Stereo. This one shows a few more things. Looks like there is storage under the drivers seat and the whole right side under the rear seat is for storage. Or for a Aux fuel tank!!
Btw three adults in the back looks miserable! Not sure anyone would actually put three adults back there?
Nothing funnier than back in the day seeing 4 fat dudes in a Rhino trying to mob through the dunes. 2 adults maybe, certainly not 3.
Little slow...
I saw this too. I read in another article that the H2 engine tune defaults to Normal mode 80% power. I don’t know if that means each time you start the car it’s in normal mode? It did say you can switch on the fly.
So was this guy in normal 80% power mode or did he know to toggle it to full 100% power mode? Because your right, it was not as close as Id expected it to be.
I had about 10 minutes to spare so I thought I would have some fun, like I usually do in these new threads!
Don't hate too bad...Like I said, I had limited time to do this!
Maybe the new 2-seat version????
fixed LOL
Only time 3 adults will be in the back is when your buddy did something dumb and needs a ride for spares. :ROFLMAO:
Kawasaki has always sucked at CVTs. That was my original concern. Time will tell.
On Edit:
On the KRX Forum, Steve Cornell has been overcoming clutch wear and performance problems on the KRX and the Ridge. He is now working on H2 solutions, as well, plus STM and others will be in the game, I'm sure.
Agreed.
It's supposed to be a different CVT, but probably just upgraded...time will tell. I wonder how big that belt is compared to the PRO R?
A heavy-duty CVT with a 17.6mm belt was engineered specifically for this machine. It features optimized cooling ducts, double the airflow volume of the KRX 1000, and real-time belt temperature monitoring on the dash.
