Electricveins569
- Dec 18, 2025
- 6
- 2
This came off the original built Subaru 2.0L Sand Car before I upgraded to a larger motor/turbo/fuel system. Worked great when removed, so nothing wrong with it. The below info is what I can gather from the casting part numbers.
IHI RHB31 turbocharger (Spec: 31E15 / BS22) originally removed from a Subaru project. This is a compact, high-quality turbocharger highly sought after for small-displacement engines, motorcycles, and "mini-turbo" projects. Specifications: Model: IHI RHB31 (B32CAD-S0015B) Housing Size: 15-R (The desirable mid-range turbine housing for balanced spool/flow).
- Condition: Used but in solid working order.
- Shaft Play: Minimal side-to-side play; no in-and-out play (blades do not touch housings).
- Wheel Condition: Compressor and turbine fins are clean with no chips or pitting.
- Housing: No cracks in the turbine/exhaust housing.
Motivated & Open to Reasonable Offers!!!
Located in Wittmann, AZ
Pickup in Wittmann (Shipping available at your cost when paid in FULL)
x-Streets - 247th & Patton
