HPI Baja 5B Gas W/Lots of Extras, No Radio
emgee00
HPI Baja 5B Gas W/Lots of Extras, No Radio $750 Firm. Only missing a radio which can be bought for as little as $40
Specs:
Features Summary
  • Unassembled 1/5th scale Off-Road Buggy
  • Ready for your 23-32cc RC engine
  • Ready for your electronics
  • Enclosed radio box
  • Baja desert racing body design
  • Adjustable HD shock absorbers
  • Monocoque chassis
  • Low CG for superior handling
  • Long travel suspension
  • Viscous torque oil-filled gear differential
  • All-terrain tires
  • Beadlock wheels with metal insert hubs
  • Aluminum rear shock tower
  • Hard plastic skid plates
  • Adjustable rear wing
  • Quick access to all critical maintenance points
  • Dual bellcrank steering
  • Cam type servo saver
  • Race spec Hex socket hardware
  • Gunmetal anodizing
  • Full set of rubber-sealed ball bearings
Chassis Specifications
  • Overall Length 817mm
  • Height: 255mm
  • Width: Front - 460mm; Rear - 480mm
  • Tire Track (to center of tires): Front - 395mm; Rear - 400mm
  • Wheelbase: 570mm
  • Ride Height: 76mm
  • Suspension Travel: Front - 95mm; Rear - 100mm
  • Weight: 9.6kg (21.3lb)
  • Adjustable Camber: front - shims; rear - screw
  • Front caster: adjustable with shim 22 / 25.5* / 29 degrees (* stock)
  • Toe-in: Front adjustable with tie rod; Rear adjustable with inserts 0-4 degrees (3 degrees stock set-up)
  • Aircraft aluminum 6061 T6 monocoque chassis
  • Double wishbone suspension with adjustable roll center F/R
  • Drive system: HD metal gears with sealed gear box (8.382:1 gear ratio)
  • Differential: viscous torque control with 4 pinion gears; sealed diff case with silicone oil
  • Shock absorber: HD Aluminum coilover shock absorber with fully adjustable preload collar
  • Wheel type: 3-piece beadlock design, high impact nylon material with inset heavy-duty metal hex hub
#160323 BAJA 5B GAS SBK
1/5th Scale 2WD Gas-Powered Buggy Self-Assembly Kit with Clear Body
SPECIFICATIONS:
Length: 817mm
Width: 480mm
Height: 255mm
Wheelbase: 562mm
Drivetrain: RWD
WHAT YOU NEED:
Radio system with transmitter, receiver (Included), large scale steering servo (Included), 1/10th scale throttle servo (Included)
23-32cc RC engine with muffler or pipe (Included)
Hump style receiver battery with Tamiya plugs plus a suitable charger (Included)
Additional Pics
Hit up Orange_R; he likes weird lawn mowers.
