House fridge ice maker
MegansDad
My KitchenAid fridge ice maker is giving me problems from making odd shaped, too little ice, and now no ice. For the last two days it seems to be getting no water to the tray and shuts itself off.
I have replaced.
Sensor control board.
Water inlet valve.
Fridge filter.
And even the actual ice maker, I have switched out ice maker with original one and same results.
What am I missing, is there a pump that can go bad.
Any experts in central San Diego that want to look at it?
May sound stupid but have you double checked the supply line, make sure it hasn't become clogged.
Yes I did.
One thing I did notice is the flow of water(to fill a cup) seems less. That’s is why I asked about a pump going bad.
Yes I did.
It should just use standard main pressure. If you pull the line off the back of the fridge, how's the flow?
Is there a inline filter on the back on the main line going to the fridge? If so it could be clogged.
the line runs inside the unit. mine would freeze up behind the crisping drawers. might make sure its not froze up.
Mine did this twice. Froze up and then would flood the kitchen. I disconnected it and switched to ice trays about 10 years ago.
Is the fridge fed by an RO system? If yes, the bladder in storage tank is likely pierced or has inadequate pressure.
