Fuel Transfer Tank For the Dunes
cek
Looking for a truck bed transfer tank to use to refill biggies at the dunes. Would like to find 75 gallons or so that would fit under a tonneau cover. Anyone have any suggestions?
Under the tonneau cover is a must.
Appreciate it but I’m looking for someone who has used one and knows it will fit under the cover. I have a transferflow tank that should fit by their dimensions but they don’t count the filler neck in their measurements.
I'm in the same situation. I've always had a transfer or auxiliary tank for diesel in my truck bed. My new truck has a folding bed cover and I like it. My buddy had a bulk refueling business (where Balin works now) and he said he can get me a tank that will fit under the be cover. It needs to be under 22" and I will have a 3/8" NPT fitting on the bottom and run a small pump to my trucks fuel tank. I'm not going to have a transfer pump because that will be too tall. I'll let you know what I end up with.
i have the 109 gallon transfer flo it does not fit under the cover unless you drill a hole for the filler neck. i drilled the hole in my cover i love it i dont have to take the cover off to fill and have a long hose so just open the gate and refuel. i have a folding bed cover and the first piece is about 8 inches and the hole is in the middle of that and when you fold it up the last fold flat is over the tank
That’s the one I was looking at. Wonder if I could cut the neck off and make it flush mounted.
I had KSH in Havasu quote a tank few years back but my plans changed. Seems they build to suit.
