2005 Moho Chevy 8.1 Fuel line replacement
Cookie
I have a 2005 Pace Arrow Motorhome with 8.1 Chevy/Allison tranny (workhorse chassis) set up. Went to start it and guess what the fuel line is leaking. I got it off, but figuring out replacement parts for Motorhome engines is always fun, lots of options out there, but not exactly the same set up. Some options are full stainless braded lines to all rubber. Here is what was taken off. Part number is still on the line, but can't find any reference, going to run to dealer in the morning, not optimistic. Any ideas are appreciatedfuel line.jpg
Might just double check that the new line is compatable with todays ethonal fuels :)
It looks like Summit has the push lock female ends and you could make the hose. If you are in so cal, check with G and J in Ontario and they can probably make one for you.
I am thinking the same thing, get the push lock ends and make a hose. The lock ends are standard in a lot of Chevys, so this shouldn't be an issue.
I did find the part on a Workhorse chassis site, but they are sold out and have no plans to get back in stock. There are aftermarket options, but the info online is not very detailed. Need to see these in person.
So I had a coolant line go bad on my 2011 Duramax and my dealer told me it was backordered for 12 months. If you can get a part number, you can call some dealerships that can run a trace on the part nationally and find a dealer that might have it. I was able to find my coolant hose in Colorado and have it shipped out. Might be worth a shot.
Found the answer to this problem. AN makes a fitting that you can use on factory Chevy fuel lines (clip on). Super easy to use as well. This allowed me to make an entire new fuel line (steel braid of course). Best looking fuel line for a Moho, and nobody will ever see it...haha
Another option if someone else runs into this is to just replace the rubber. It’s clamped on with regular clamps, and Dorman sells 3/8” quick connect lines with clamps for the fuel pump and rail sides.
Yore lucky you found the issue, before something bad happened.
We lost a Pace Arrow to a leaky fuel line. My Dad started the MH up for a trip to Magic Mtn with a bunch of kids, walked to go grab a cup of coffee from the house and before reaching the kitchen saw the front end engulfed in flames, entire unit was gone before the FD showed up 6 mins later.
For sure. I started it up, then walked away for a couple of minutes to do something else, came back with about 2 gallons of gas on the ground underneath, leaking all over the hot exhaust. Super lucky.
that is what @ChasingSand was explaining, that they make GM-Flare to AN fittings, pretty standard just measure the size of line, it will be a 3/8 or 5/116 ect...
^^^^ this is exactly what I used, where were you guys last week when I has figuring this out, haha.
Entire new line with fittings was under $125. They also make a plastic one that you can put clamp a rubber hose onto as well
Plus:
Plus:
Plus the appropriate 3/8" ethanol safe FI line on the stock hardline and you're back in business lickity split with OE-style everything. AN is nice, but all of this can be picked up at any O-O-O'Reilly's and you're back on the road in an hour. :)
