- Thread starter
- #101
ROBERT L
Moderator
- May 2, 2021
- 5,151
- 3,873
Yea I should pay attention to what I’m cooking instead of drooling over what you’re cooking.I post my not so good cooks too! At least there is pizza to order! :lol:
I think you KILLED IT with that cook!! I bet No one got sick with salmonella
i competed in KCBS comps for 5 yearsw, i learned at my first comp that fall off the bone is technically overdone.. you want em just before that stage. you should be able to cleanly bit thru and pull bone away without pulling all the meat off.For some reason, I cannot get my ribs to turn out correct on the smoker. I am using a masterbuilt 560 charcoal smoker. yesterday was my second set and while tender, they were not exactly fall off the bone. I pulled them at around 190 degrees. Was this too early? is 200 degree's the magic number? I cooked them for almost 5 hours (Unrwapped) at 225. Any tips on how to make better ribs?
I agree with @Kevin fall off other bone is overdone. Want to see a little/slight tug when I bite into the rib. My method is also similar to his. Around 225-250* depending how thick the ribs are. Smoke them for 3hrs then wrap for 45-1hr. Take them out the wrap and glaze for 30 minutes. Perfect every time. I sometimes probe for temp and it’s about 200-205*For some reason, I cannot get my ribs to turn out correct on the smoker. I am using a masterbuilt 560 charcoal smoker. yesterday was my second set and while tender, they were not exactly fall off the bone. I pulled them at around 190 degrees. Was this too early? is 200 degree's the magic number? I cooked them for almost 5 hours (Unrwapped) at 225. Any tips on how to make better ribs?
