ANGRYBUTTCRACK
- May 6, 2021
- 1,891
- 1,601
That's the record (number) that I remember from years back..Had to make a bonsai run to storage last July, it was 121*.
abc
But you have one, dont you buddy????Sure thing. That house doesn't have a pool. It will be back on the market by Labor day.
122 is The record in Phx. as well, I remember the day well. I had to work in a building that had no AC, then drive home in my VW bug that had no AC. that was a pretty brutal day to say the least.That's the record (number) that I remember from years back..
abc
No.But you have one, dont you buddy????
Where did you say that RoberL lived again???? LOLNo.
Pools are like boats. Sht your friends need to own. Most of my friends couldn't fabricate themselves a way out of a wet paper sack, so they bring it to me. In trade, I come over to eat their over cooked hotdogs (see RobertL's post from last weekend) and pee in their pool... Being a decent American, I bring my own beer.
:shocker:How hot do attics get in Arizona?
"Our attics in Phoenix can reach over 180 degrees and then drop down to 50 degrees or lower in the winter. That's 130-degree temperature change,” Harb said. “Expansion and contraction and those high temps as well as the moisture from rain, especially during our monsoon season, will cause damage to your belongings.”Aug 24, 2018
Try this instead.If you store your trailer ive been experimenting with different ways to evacuate heat.
One way is to replace the existing stove fan with something better. You could run that off the trailer batteries that are replenished by solar. Or hook up a tiny solar panel that makes the fan run when the sun comes out.
Benefit to using the stove fan is that most will open and close based on how fast the fan moves. That means less dust and less chance of bugs entering when the fan is off.
Negative is that its not taking air from the rooftop where heat collects. It does help though. This time of year my stove fan is running 24/7. All i do is adjust the speed.
I found a 140mm computer fan will fit through the existing hole. Just sit there and do its thing.
Went with a 2000RPM version instead of the 3000RPM because our trailers will see 14.4v at times. That fan is designed to see 12.5v or so.
https://www.amazon.com/Noctua-NF-A14-iPPC-2000-PWM-Cooling/dp/B00KFCRMSG/ref=sr_1_8?crid=L7ZTQEDAMFAC&keywords=noctua+industrial+fan&qid=1654564237&sprefix=noctua+industrial+fan%2Caps%2C151&sr=8-8
Nailed it, LOLThe Az and Vegas guys are just sitting back and giggling at you softies barking about 110* temps...LOL
I'm honestly hoping we see 120+ for a few weeks this summer. Drive all the "Hi, I'm Bob. We just moved here from California" MFr's back home. Probably move some of the homeless back to Seattle and Portland.
Off topic - I know... Those records were set over 100 years ago. With all the GLOBAL WARMING (now we call it CLIMATE CHANGE), one would think those records would have been smashed by now and then beaten again year after year.You could guess Glamis must have been REALLY close to this historical record...
The record high temperature in Brawley was 123.98 degrees on August 16, 1903
Official world record remains 134°F at Furnace Creek in 1913
Eff all that nonsense. :sun:
Let’s go!!!I remember a couple summer trips back in the day when it was over 120*F. Fired up the genny and both roof airs in the 5er when leaving El Centro Friday and they didn't shut down till Sunday. All windows covered with Reflectix so it was basically pitch black in the trailer and super comfortable. Burned A LOT of gas in the genny those weekends but the sand and riding was worth it.
