- Thread starter
- #21
Dune-Track-N
- 961
RuffStuff and yes I'll be hitting rocks even with 2WD
Yes, but it was also always the plan to use a TH400 in all the build ideas I've had.Curious; are you using a TH400 because you already had it? Yes, they are strong and reliable but only a 3 speed. Wondering if you will be happy with the jump from second to third and back?
@Dockmaster just for fun I ran the calculator for 1st gear speeds.Yes, but it was also always the plan to use a TH400 in all the build ideas I've had.
Simple no need for electronics or tuning nighmares with the 4L###'s. I have more then one friend who cannot keep or get the trans tune right on their rock buggies. The VSS signal, transfercase's and gear ratios just seem to be a wild card. I know there are PRO's and people with zero issue's but I just have always planned on the 3-speed and simple.
way to fast....
probably OK
cruising speedsYeah, I was looking for "hot rod" headers like these:@Rockwood I think the block huggers might work. For $200 it's not a bad option to try, but.... EBAY has C6 Vette manifolds for $130-200
Summit has these https://www.summitracing.com/parts/sdm-pce316-1061
I'm worried the "height" of these will still not clear the frame at the collector. All the reviews say these hit the motor mounts and if you look at my frame rail thats where it also transitions wider. A lot going on in that space...
