onanysunday
- May 6, 2021
- 3,964
- 3,580
I know a lot of people do it but how much is reasonable and what you can get away with? Or do you just flat out weigh everything and make sure you're not going 1 lb over. Example right now is I'm looking at an '06-07 Duramax single rear wheel crew cab 2500 truck. Would like to put a toy hauler behind it with the Funco in it. In my other thread I used an example. That truck has a tow rating of 12,000 lb. Just one of the trailers posted came in at 8,500 lb dry. I have to assume that would be fairly normal weight for a toy hauler of that size. Weight rating on that particular trailer is a little over 14,000 lb and with the buggy and all the gear in it I could see it being easy to get it up to that weight. So how many of you think it is okay to tow a couple thousand over? Or not?
