1HasBeen
- 1,695
I was told Yamaha is exiting the pump and generator business.
The new Hondas have an app that can give you all kinds of infoKeep in mind all of these gens need valve adjust. Normal is 300 hours. I had 2 Honda 3000 hit valves for lack of doing it. My bad. It is a pain to do on Hondas.
Dam Hondas do not have a hour meter. Easy to loose track of how much time on them.
I purchased the Yamaha EF2200IS a couple years back, loaded with great features and built really well...best design for a suitcase style portable Gen......the problem...that little 79cc engine they use on these....had no balls...They claim it's 2200 watts just like the Honda's....but the Honda uses a 121cc engine....there's no replacement for displacement!I was told Yamaha is exiting the pump and generator business.
I have a pair of Yamaha 2200s and they run 2 15k a/cs in parallel. I can run 1 a/c and charge my batteries (I charge at 85amps). I can run other stuff at the same time as they will "boost" for a few minutes for things like the microwave. The Yamahas get noisy at full tilt and the CO sensor is quite sensitive but if you point the exhaust 180 from one another they will stay running.Wonder if a couple 2200’s would work or should I start looking for 5k
Yes, Honda 2000. Still have it but it takes about 15 pulls to get it started the first time.......thanks for reminding me, this weekend would be a good time to pull out the generators and run them. I guess I could clean the carb in the Honda.I like the one @Spize909 had, cause when I needed to borrow one, he loaned it to me and it ran perfectly.....a honda i'm thinking.
Carry on LOL
You just need to clean the jets and it'll run perfect again.I bought the Honda EU2000 and the Harbor Freight equivalent at the same time. I did the same break-in and service for both.
We kept experiencing long power outages in my neighborhood and I need to make sure my multiple freezers/fridges and kids entertainment centers wouldn’t be offline for those extended outages.
We always ran both generators with same fuel simultaneously with similar loads and run times.
I think it has been between 6 & 8 years.
The Honda is still great.
The Predator surges unless it is under load at a higher rpm.
Harbor freight made some slight improvements to the Honda machine when they “borrowed” their design, just not in the running department.
The Honda was almost double the price, but I kind of wished I had just bought 2 Hondas Or one larger Honda unit.
