Probably with 20-30psi in them as well. SxS guys universally run pressures higher than what I run in my 4000lb Jeep on the street. :biggrin:Probably a little of both, the "Jack" and those tires and running in 4wd.
Mind blower, x3 and 2wd with the proper sand tires ... Sweet Jack n a.
Really ?. Lol. And no beadlocks. Who needs beadlocks at 30psi !.Probably with 20-30psi in them as well. SxS guys universally run pressures higher than what I run in my 4000lb Jeep on the street. :biggrin:
Robby says you can’t run less than 10psi with his beadlocks… AKA the same-ish pressure I run in my Jeep without beadlocks…Really ?. Lol. And no beadlocks. Who needs beadlocks at 30psi !.
Wobby who ?. The same car that has a problem with sand ? LolRobby says you can’t run less than 10psi with his beadlocks… AKA the same-ish pressure I run in my Jeep without beadlocks…
No one. Point was more that its more air than you need to keep the bead on a 4,000lb Jeep...Who really cares what you jeep guys run in your tires anyway.
Oops![]()
The Speed wheels do not like anything below 10psi. RG had a few come off the inner bead in the dunes.No one. Point was more that its more air than you need to keep the bead on a 4,000lb Jeep...
I think that is where the EVO transmission tune will be helpful.Yeah. One of his complaints was how the geared transmission was fighting the suspension, and that's definitely a skill thing that takes some learning. My buggy behaves VERY differently suspension wise based on the gear its in, and learning the good gear for whoops and other things definitely changes how effective the suspension is at handling whatever its dealing with.
Yeah. He was testing in the desert, land of endless whoops. There's a point where you can't keep mashing it... :biggrin:I think that is where the EVO transmission tune will be helpful.
I did not notice the issue he talked about when I drove my friend's in Glamis. Mind you I was just mashing through the whoops in the dunes and washes.
That point is either when you snap an axle or the ass end of the car decides it wants to be the new leader and passes the front. LOL!Yeah. He was testing in the desert, land of endless whoops. There's a point where you can't keep mashing it... :biggrin:
